Este nuevo crono lleva el calibre 25B, heredero de la magnífica patente de 1926 de Breitling, cuyo único movimiento lleva una aguja central de segundos que da una vuelta cada 30 segundos en lugar de cada 60, de modo que la subesfera de las 6 hace una lectura de 1/8 de segundo
Movement Automatic, Breitling 25B calibre, COSC-certified chronometer, 38 rubies, 28,800 vib/h
Functions Hours, minutes, seconds, date, 30-second chronograph, 15-minute and 6-hour totalisers. Variable tachometer
Case Steel or 18K red gold (limited to 500 pieces), 48.7 mm
Convex sapphire crystal, anti-reflective treatment on both sides
Ratcheted rotating bezel with variable (circular slide-rule) tachometer
Water-resistant to 100 m
Dial Black Velvet, Silver Storm or Bronze for the steel or 18K red gold models
Neptune for the steel version only
6-hour, 15-minute and small seconds at 6, 9 and 3 o’clock respectively
Date window at 4.30
Bracelet/Strap Barenia leather, crocodile or rubber strap, or metal Speed bracelet
Date window at 4.30
